4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#243384 11/30/2004 10:57 PM
I have a seat assm original for a 49 Chevy truck will it fit into a 51 burb or are those two different?
Thanks Mark
#243385 12/01/2004 3:25 AM
The seat riser is not as wide on the suburban due to the 60/40 seat. The suburban has a "jump seat" on the passenger side that bolts to a metal plate on the floor and tilts all the way forward allowing the passengers access to the rear. You would have to either remove the seat riser from the truck and replace the suburban riser or build up the floor to allow the wider truck seat. The cab width are the same and the seat measurement would not be a problem.
Are you missing the original Suburban seat? .....g
#243386 12/01/2004 2:27 PM
I Have someone Interested in my seat assembly to use in a burb so i don't know if he is missing it or if it is just worn out!
If you have one I can relay the message to him!
Thanks Mark
