| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | I have a seat assm original for a 49 Chevy truck will it fit into a 51 burb or are those two different?
Thanks Mark | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The seat riser is not as wide on the suburban due to the 60/40 seat. The suburban has a "jump seat" on the passenger side that bolts to a metal plate on the floor and tilts all the way forward allowing the passengers access to the rear. You would have to either remove the seat riser from the truck and replace the suburban riser or build up the floor to allow the wider truck seat. The cab width are the same and the seat measurement would not be a problem.
Are you missing the original Suburban seat? .....g | | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | I Have someone Interested in my seat assembly to use in a burb so i don't know if he is missing it or if it is just worn out!
If you have one I can relay the message to him!
Thanks Mark | | |
