| | | Forums66 Topics128,160 Posts1,057,051 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Over the last 2 days I have been able to fix the exhaust system and replace the muffler, fix the oil sending line, replace the leaking pushrod cover gasket and valve cover gasket, replace 3 studs stripped by the person who installed the tires on the front, paint the valve cover and pushrod cover and go shopping with the wife. The coolest part is the muffler. I can now hear the engine. Of course we discovered the water pump bearings are making a bad noise. And after installing the gaskets I cranked the truck to move it out of the garage and noticed gas dripping from the fuel pump. Dang. Fuel pump, water pump. I think this truck sat up longer than a couple of years. This explains why it stinks of gas all the time.
Is there a fix for this leaking problem? The connections seem tight. Does anyone recomend the dual action fuel pump to help the vacuum wipers? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | If he hasn't completely closed down yet, get in touch with Gardner's Auto Parts on Trinity Lane, just north of Nashville. Johnny Gardner was in business for at least 50 years, and probably has more old stovebolt stuff in stock than you could haul away with a fleet of trucks. He will probably have a double-action fuel pump in stock, possibly one he bought back in the 50's when the truck was new! I've heard he's in the process of closing, and there might be some real bargains on NOS parts. Jerry
| | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Old stock fuel pumps are not likely to last long with the modern gasoline/ethanol blends. Look for a replacement diaphragm kit or a modern pump designed for the modern gas. Time to replace the hoses as well on the fuel line too.  | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Good idea on the hose. It's nasty anyway. After painting the valve and pushrod cover all the nasty stuff is showing up brightly. Should I paint the fuel pump and water pump? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | A little paint can't hurt either one, but it's generally not done on a fuel pump for some reason. Jerry
