9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24323 10/15/2002 4:20 AM | Joined: Jun 2002 Posts: 50 Member | | Member Joined: Jun 2002 Posts: 50 | How in the hell do you take the wiper blade arms off. I've pulled and yanked everything I can think of and can't get dang things off. HELP :mad:
If it ain't broke I ain't worked on it.
#24324 10/15/2002 5:47 AM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit guy! unsure of your year truck; my '56 arms has a small clip, under the arm, which hooks onto the splined hub. you need to make sure that it's not locked in. THEN...spread a towel/T-shirt around the work area. i use two flat-bladed screwdrivers, to pry the arms off, at the base. it always pops off...right onto the towel/T-shirt.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#24325 10/15/2002 2:34 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | If you have a Ma and Pa auto parts store in your town go to them and ask them if the have a Wiper arm removal tool. They may have one in the back that you may borrow. It wont look like much but a flat piece of steel that has a 2 prong fork bent at aprox 45 degree at one end. Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
