| | | Forums66 Topics128,090 Posts1,056,015 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 13 Apprentice | | Apprentice Joined: Mar 2005 Posts: 13 | Does anyone make a power steering conversion for 65 1/2 ton 4 wheel drive? I have seen the kits for the 2wd but not tht 4wd. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I don't think anyone makes anything for it. Unfortunately you'd probably have to swap out the whole front axle to get PS. You might be able to fabricate something with maybe a Toyota box or something. Maybe a PS setup for a straight axle truck could be adapted. But there's nothing to bolt up. I don't believe the factory had PS in 4x4's until '67. | | | | | Joined: Mar 2005 Posts: 13 Apprentice | | Apprentice Joined: Mar 2005 Posts: 13 | Thanks for the reply. The truck now has power steering. It has a piston linked to the long tie rod. It has an old gm power steering pump. Don't know if that was a dealer option or just added at some other time.And it works ok but getting old. | | |
