9 members (Otto Skorzeny, Cosmo, RAC1812, cmayna, GRNHydra, HandyAndy, Peggy M, 1955 1 Series, 1 invisible), 144 guests, and 1 robot.
Topics128,087
Posts1,055,982
Members48,430
#243202 05/01/2005 2:29 PM
Apprentice
Apprentice
Does anyone make a power steering conversion for 65 1/2 ton 4 wheel drive? I have seen the kits for the 2wd but not tht 4wd.
#243203 05/01/2005 2:59 PM
k10 Offline
I don't think anyone makes anything for it. Unfortunately you'd probably have to swap out the whole front axle to get PS. You might be able to fabricate something with maybe a Toyota box or something. Maybe a PS setup for a straight axle truck could be adapted. But there's nothing to bolt up. I don't believe the factory had PS in 4x4's until '67.
#243204 05/01/2005 4:17 PM
Apprentice
Apprentice
Thanks for the reply. The truck now has power steering. It has a piston linked to the long tie rod. It has an old gm power steering pump. Don't know if that was a dealer option or just added at some other time.And it works ok but getting old.
