3 members (Bill Marlow, 2 invisible), 109 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#243141 11/07/2004 2:49 AM
#243142 11/07/2004 6:07 AM
Man that's nice and clean! As I was replacing my water and fuel pump today I was also cleaning 45 years of crud off whereever I could reach. If I had had a whole extra day I would probably have removed the front end and cleaned the frame.
It will have to wait.
Looks great!
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#243143 11/08/2004 12:06 AM
Garretthes Thanks for the nice words, trying to do the best job I can and it only happens with the advice I ask for and receive on this great STOVEBOLT page!
#243144 11/08/2004 8:00 PM
Moderator
Moderator
Weeds, thanks for the photos. Still pondering exactly what I want to do to my 1 ton panel to get IFS. Can't go MII on anything that heavy.
Thanks again!
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#243145 11/08/2004 9:41 PM
Weeds The IFS looks great. I put a 69 Nova clip on my 49 burb. Turned out good but not as seasmless as the 84 in your pictures. Can you give me some details on what you used? Did you take a section out of the middle to make it fit?any in process pictures. Thanks in advance for the help.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#243146 11/09/2004 12:57 AM
Junior Member
Junior Member
hey guys...thinking alot lately????hey WEEDS,every front clip i come across is about 2inches wider than my 50 frame rails ..was the 84 just right or did ya have to cut and shorten the bottom belly ???and what rear end are ya going to go with ??????????.........gary
#243147 11/09/2004 6:06 AM
hey what did you do to the frame. Sand blast acid bath then paint or powder coat. your turned out real nice and its almost time to start painting or powder coating mine.
#243148 11/09/2004 6:03 PM
Weedz-
What a clean foundation for your build-up. Sweet!
#243149 11/09/2004 6:22 PM
Weeds looking good buddy!! We can't play ball so its time for more work on the trucks. Ben
popcorn The Truth is Out There (I have got to learn to post pictures) I will.
#243150 11/10/2004 2:18 AM
BradB, 49Bourbon, GARYS, 61 Apache, 51Phat and old pal Korn ( Go Cubs?) you guys are too nice. I think I have finally got the hang of posting pics. I have a bunch of them and will try to get them up. Try to answer all your specific questions. BradB I went with the 84 GMC IFS mostly because I am cheap and secondly it is a TRUCK front end. M2s may be just fine but I am not all that impressed. I picked up the 84 IFS and rear end from a boneyard in Missouri for $350. 49B yes I had to take an 1 5/8 out of the middle of the 84 C- member. This allows the whole assembly to bolt up to the AD frame without shims in the correct position. It can be done without cutting the C-member but a 1/2 to 9/16 shim would have to be used on each side. GARYS, using the 84 rear end out of the same truck with 2:73 gears. H-Rod Lincoln says should work OK with my 283/Th350 setup. 61 Apache 10, I had a local guy sand blast the frame and IFS and then went with NAPA crossfire self etching epoxy primer and black acrylic enamel. A disadvantage to this setup is that when done the ride height is about 2 to 3 inches higher than normal so you have to use drop spindles to get back to stock height, Also the track width is wider so wheels with sufficient backset must be used. Never expected so many positive replies. This started out as just an update on engine, brakes etc. etc. but it turns out I guess I am actually building a street rod but what fun. You guys are OK and I could never attempt this project without this great site. Will try to post more pics.
#243151 11/10/2004 2:48 AM
Junior Member
Junior Member
WEEDS...looking great, and thanks for the reply...i was orig. thinking of putting the whole truck on a 92 chassis,only because it was a freebie and i really didn't stop and think of what i could do with the orig. chassis.i mean i didn't want to butcher up a good chassis because maybe someone might need or be interested in the chassis for an orig. rebuild.....keep the pics rolling and keep up the great job..you'l have her up and going in no time .......regards............gary
