2 members (G508, Hush),
128
Mod | | | Forums66 Topics128,271 Posts1,058,414 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 22 | Does anyone know where I can find the weatherstrip for all the rear side glass and rear clamshell glass also if there's someone that sells rear glass sets just the sides don't need the rear. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Chevs of the 40's sells the rear window seals and the side glass. | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Pulled all of the side glass out of my '50 burb this weekend. None broken out but half of them are cracked and all are discolored. I am going to use this set to make templates and have a local glass shop make new glass for me. The last local glass I had made was perfect, cost a less than catalog price and no shipping to worry about. Check local prices if you have something to work off of.
Buddy | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Buddy,
Were the cracked panes the sliding pieces? All mine were cracked from being slid too far forward. I have put a "stop" in place that cannot be easily seen (in fact, it looks "natural") - a piece of black thick-wall tubing pressed into the run channel on the front side. When the glass is pushed forward, it is stopped by the edges of the tube in the run channel(top and bottom).
Tim | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | My cracks were from something hitting them from the outside, not from the edges. I like your idea though! Better safe than sorry.
Buddy | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Manual Check Steele Rubber as well. Don't know which is cheaper but think Chev of 40's, etc. resells someone else's gskets.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
