8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24290 01/01/2002 6:47 PM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | I decided to go with the saginaw 4 sp instead of the t-5. now that i have it i measured and every thing lines up except the bottom left bolt is set out farther than on the stock transmission. What can i do to make this work without changing the bellhousing. Thanks, Mike | | |
#24291 01/01/2002 7:08 PM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | Buck, I am wondering why you went with the Saginaw vs. the T-5? What motor are you mounting it to? I have a GMC 302 and am very undecided on what 4-spd to go with. Any help would be appreciated? Also, what is the price range on the saginaw?? | | |
#24292 01/01/2002 7:12 PM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | I paid $150 for the saginaw. I went with the saginaw because i didt want to change anything with the clutch. The saginaw has the same shaft as the stock transmission. 10 splines. i dont knwo what my motor is its either a 228 or 248. mike | | |
#24293 01/01/2002 7:53 PM | | Anonymous Unregistered | | Anonymous Unregistered | The disc is the only thing you have to change with the clutch (60 bucks new) everthing else you use stock parts. Which bolt does not line up on your bellhousing?? Cause you are pretty much stuck with it if it dont line up.Do you know what the trans came out of?? I have seen a couple of vega trans that have a weird pattern. | | |
#24294 01/01/2002 10:41 PM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | Phat, What should I look for on a used trans? How do I know it's a saginaw? Are they all geared the same? | | |
#24295 01/01/2002 11:17 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | You are talking car 4 spd right, not the heavy truck tranny?The Saginaw will bolt up to any 48 or newer truck or 55 newer car housing.Some Vegas used Saginaws some used a smaller tranny.The Saginaws have rings on the imput shaft to ID ratios. No rings, 2.85 first gear,1 ring,2.56, 2 rings,3.11 and 3 rings is the usual Vega model with a 3.50 first gear.The 2nd and 3 rd gears are spaced differently also to follow the first gear.The Saginaw is all cast iron, all three shifter shafts are on the side cover, the shift levers bolt on,the side cover is sorta square with 8 bolt I think.The trans is 21 inches long overall and has a 10 spline input and a fine spline output
[ 01-01-2002: Message edited by: Tony ] | | |
#24296 01/02/2002 12:33 AM | | Anonymous Unregistered | | Anonymous Unregistered | Formula1 If you are runnin a 302 i would go with a borg warner or a muncie.The saginaw was not a very good box and spit the cluster shaft out the bottom a lot on higher torque stuff.(i think its weaker than the t-5 plus the shifter is back farther) Dont allways go by the rings,if it was ever rebuilt and got a new cluster and input(they broke a lot of them in the chevelle's camaro's)the new ones did not have rings on the input. Pull the cover and check the teeth on the input. | | |
#24297 01/02/2002 1:22 AM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Every bolt lines up except for the bottom left on if you are looking at it from the front of the transmission . Every other one lines up except for that single one . is ther anything that i can do with this or should i get a different bellhousing. | | |
#24298 01/02/2002 1:23 AM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Oh yea the transmission came out of a 68 camaro. | | |
#24299 01/02/2002 6:35 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Buck-O-nine,
Sell the 4-speed to some one who's restoring a '68 Camaro, for a reasonable profit, and either go with the T-5 or a four speed that matches your bell housing pattern.
There are no bell-housing swaps for the stovebolt six, except perhaps to the pre-'47 bell housing, which is not helpful. You'd have to change to a later engine (post '62) to have bell housing "swappability".
There is a Dodge truck 4-speed from the '70's that has OD as 4th gear, and is supposedly a direct bolt-in; it's usually found in 2wd trucks w/ slant-sixes.
Good luck.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#24300 01/02/2002 6:38 PM | | Anonymous Unregistered | | Anonymous Unregistered | Buck you got to look close at that again.If its out of a camaro it supposed to be the same pattern .something aint right. Check it again.How far is it off??? | | |
#24301 01/02/2002 10:22 PM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | Buck-o-nine,
I looked through the posts and I did not see what year truck you have.
Rick | | |
#24302 01/03/2002 12:27 AM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | Tony and Phat, THanks again for your input, I really appreciate it. But, now you have me confused. I know everyone has their opinion, but what is my option here? I want a trouble free installation without having to re-invent the wheel. | | |
#24303 01/03/2002 1:01 AM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | my truck is a 1948 GMC Pickup. I really dont want to sell this id rater make it work am i not measuring something right? or what. | | |
#24304 01/03/2002 2:33 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Buck, all the Saginaws and Muncies T-5's etc have the same bolt pattern.your 48 ,first year of the AD model may still have the older style small bolt pattern.You may have to change the bellhousing.I owned a true 49 GMC that had the newer style bolt pattern. Formula, some guys say a 302 is too much for a T-5 Some guys say its too much for a Saginaw.I have personally known 2 or 3 guys that used Saginaws with no problem and one guy with a 302 T-5 combo that towed a trailer with no problems. And I tore the cluster gear out of a T-5 behind a feeble 2.8 v-6 S10 .Try the tranny of your choice and let us know if it lasts.Then we will have a first hand account.There's a certain guy with a 341 inch roller cam GMC 6 cylinder that Phat is not too fond of.He runs a Camaro T-5 in that car with no problem. So either the trans is strong enough or his engine is all show. If you get the same answer out of two truck nuts, one is lying. | | |
#24306 01/03/2002 4:17 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Buck,
What tranny was originally in your '48 GMC?
Was it by chance a floor-shift 3-speed?
Column shift 3-speed?
The earlier tranny pattern on the truck (and car through'54) had the top two holes fairly close together(?). The aluminum bell housing in the bottom photo appears to be cast in such a way that it can be drilled to accept any of the post-54 trannys. If the bolt pattern on your bell is different from the one on the green bell housing in the picture, than I'd say you have the early pattern housing on your engine, which is very limiting: you'd need to change to the '49 to '53 bell housing to mate the later trannys.
#24307 01/03/2002 10:50 PM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | It is a 4sp. tranny. The 49 bellhousing looks like the same bolt pattern as my saginaw but my bellhousing isnt that far off. | | |
