2 members (Nick in Manitou, 2-Ton), 333 guests, and 8 robots.
Topics128,159
Posts1,057,039
Members48,460
#242893 01/11/2005 6:34 PM
I've got a '46 Panel and put a MII frontend under it. Well when I went to hook up the coulmn I found that the splined end of the rack was to close to the upright portion of the crossmember. I've talekd to all the manufacturers and the only thing anyone could come up with was to notch the crossmember. Has anyone one else run into this? If you have how did you fix it? Here are some pics of the problem.
Steering shaft
Streering shaft2
Steering Shaft3
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
#242894 01/11/2005 11:30 PM
Bluepen- No experience but doesn't look like you have much choice. Seems like if you got some thick wall steel tubing, slit it in half, and then used it to reinforce the notch it should work. ( similar to how to do a notch for lowering rear axle) I'd post it over in the engine & driveline forum as they answer rod questions pretty regularly to see if you get a hit.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
