| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 39 | I just replaced the rubber around my wing windows, Now there is a gap at the top and the bottom of the inner frame overlaps the rubber at the bottom. The following pics are taken with very little tension on the spring probably not enough to keep the windows open while driving. If I tighten up the tention the problem gets worse....Anyone else ever have this problem?? How can it be fixed?? Thanks, Bottom Top Full view | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like the glass frame is possibly out of shape. I notice there's no glass in it, perhaps once there's glass in the frames, which will help tham maintain their proper shape, they'[ll seal up better.
Bill Burmeister | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | When I pulled the wings out of my 55 2nd to replace the glass I had the same reaction. Remember that you have them out of your truck. The frame will get bent out of shape. When I put the frames back in the truck I found that I had to bend/staighten the frame to fit the door. I found that when the wing frame was finally screwed back into the door that they staightened out. With a little adjustment on the tension spring you will find that moving the inner frame up and down will play out your gap on top and bottom.
Good luck.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2005 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 39 | Longbox, that was my first reaction as well ...I test fitted the glass and it fits perfectly. I guess I'll try to mount it in the door and see what happens. Thank you both for the replies.  | | |
