1 members (Jimmie D), 110 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
Junior Member
Junior Member
HELLO, I am new to the forum, I have put together A 1987 Blazer with 1968 cadillac rebuilt 472 and rebuilt th 400. also rockwell t221 transfer case. can anyone tell me if they know how to modify the transfer case so that you can have either front or rear wheel drive. any information would be greatly appreciated. mudrunner
mudrunner.
Junior Member
Junior Member
mudrunner,
this is my first post also. in response to your question, the answer is no. there are two forks in your T/C. the mode fork is either in nuetral, or coupling the input & rear output. the range fork couples the front output in either Neutral, Hi or Low range.
the only way to have front drive only, is to remove the rear driveshaft.
potshot
