2 members (LAROKE, baldeagle), 63 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#242696 10/22/2007 4:33 PM
Hello again,
I need advice on how to soften up the ride on my 52 3/4 ton pu. I replaced the front springs, shackles and shocks with new original parts, but that didn't improve the ride very much. I would like a cheap solution without much modification.
Highway radial tires have helped, but I still would like more. It feels like I have no "spring" in the front end.
Any advice would be appreciated!
John Schommer. Bolter#12041
#242697 10/22/2007 5:00 PM
IFS
#242698 10/22/2007 6:16 PM
These ol' bolts do have a stiff ride, especially the 3/4 and 1 ton. One thing that will help is to put some "poly" or teflon liner between the leaves to help them slide. Easy to do and cheap. It is available from many of the usual suppliers. If you don't mind a little lowering you could remove a couple of leaves as well, this will soften up the ride too. Other than that, just cinch the seat belts up tight, hang on to your coffee cup and enjoy!
#242700 10/22/2007 10:45 PM
What is your tire PSI? I believe you can remove a leaf from your springs to soften the ride. Perhaps someone else has a better suggestion.
~Jim
#242701 10/23/2007 1:34 AM
If you don't want to switch to an IFS, try the teflon as Waldo suggested. It would be the least expensive. You may also consider mono leafs.
Robert C.
I'm a Genius in the making.
1950 3600
#242702 10/23/2007 4:14 AM
Instead of spending money on Teflon find an old kid's "Magic Carpet or Flying Carpet" snow sled. These are the roll up sleds made of a Teflon type of plastic. Probably get one at a garage sale. Cut strips from it and put them between the leaves.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#242703 10/23/2007 2:32 PM
ODSS President
ODSS President
FWIW, I'm a daily driver of a straight axle year 'round and just added Bilstein shocks which were the most dramatic improvement after radial tires that I feel one can experience in these old trucks.
Quote
Good idea, may raise your truck almost an inch... spring liner with lip is something I'm going to try one of these days, the lip will prevent it from wandering.
We need somebody with 'liner experience' to add their two cents.
~ Cosmo
1949 Chevy Half Ton
#242704 10/23/2007 5:39 PM
Yes, get the poly liner made for your springs (has a lip on it) to keep it from wandering out.
I'm using this on my '53 AD, really softens up the ride and I think actually allows the truck to settle on the springs more and lowers the rig slightly. One roll is more than enough to do the whole truck.
#242705 10/23/2007 7:34 PM
For a BIG difference try a front sway bar.
~Jim
#242706 10/23/2007 11:31 PM
OK Cosmo, went to "Bilstein" shocks site and their product data base starts at 1965. So how did you come up with a number that would fit your 1949, 3100? And I haven't seen any prices but from the description of how they are made it sounds like they're setting me up for a whopper of a bill.
Denny G
Denny G
Sandwich, IL
I agree that she rides alot better with ALOT of weight in the rear. The front sway bar sounds good and I did think of a mono leaf setup. I'll have to look at the Bilstein shocks.
Maybe I should take out the set of overload springs in the back.
It does have 14 leafs on each side. I would only need to get a different set of U-Bolts to do that. I like stance of the truck the way it is, but taking the extra set out would also center the rear wheels more inside the fenders.
Thanks for the help. Bouncing's not a bad thing.
