4 members (2-Ton, jmoore, TUTS 59, WICruiser), 145 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#242616 10/21/2007 3:04 AM
I thought since the engine had to be pulled on the 57, this would be a good time to address the front end. I would like to do the Mustang II weld in kit, but finances won't allow it. So, got a hold of a 1979 Firebird for front graft and rear end - steering column. I've got the engine, fenders and such off. Started to level the car and ended up with a sore head from scratching. Question: how do you level a unibody car? I tried to level the front subframe underneath the body where it ties to the body. This is the only straight area. There is no place on the body (that isn't banged up). Should you use a line through the upper and lower ball joint centers?
#242618 10/21/2007 6:59 AM
I once cruised parking lots until I found the right car so I could take measurements at stock ride height. Basically I pulled up with a tape measure, laid down next to the car on both sides, and measured a few key points I'd already identified. I noted the tire size for reference, and made sure all four were the same.
Then I left quick before anyone took notice...
#242619 10/21/2007 4:12 PM
Thank you, Joe. That helped alot.
#242620 10/21/2007 5:12 PM
Drive a Tank over it will "Level" most cars! grin
GMC: Get More Cash...
1958 GMC
My Webshots photos
