5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
Z
ZB3
Offline
Z Offline
Well, I am stuck. I am trying to remove the threaded shackle bushings in the frame using a method I found on the bolt which is a piece of pipe, washers and my wrench to in essence to draw out the bushing but it is not moving. So, I need ideas on how to remove those bushings. They are wallered out and need replaced before I paint my frame and put on the new leaf springs. Do I need a press and where do I get that? Dynamite is too rough on the rest of the frame let alone the house but tempting sometimes! Thanks for all of your input and yes I am having fun on this truck which currently is several "Lawn" ornaments in the front of the house so the neighbors enjoy the truck in its dismemberment as well. It is a good thing my wife loves me. (Not sure about the neighbors though) Thanks, Wayne
Riding in the Passing Lane
If there is enough left in it screw the old shackle pin in it & use a big hammer. If not If not a large punch or a bushing driver kit.
1972 Chevy c10 Cheyenne Super
3B Offline
Hy ZB3, You could try using one of your old shackle bolts threaded into the bushing and drive it out with a sledge hammer, or you could use a 1/2" socket just smaller than the O.D. of the bushing and a long 1/2" bolt and the piece of pipe you mentioned to draw them out, it takes a lot of force to get them to start moving, but once they start it should get easier as it comes out, you can use the same method only backwards to install the new ones, hope that helps.
Have you tried heating the thing the bushing is in?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I used an air chisel, but you've got to make sure where you're hitting.
Come to the Great Lakes GABfest
Get all the details here!
i welded a large nut on the end of a old shaxkle pin and use it to drive the bushing out. or take your hack saw apart, stick the blade thru the bushing, reassemble the saw and have at it in one or two places.
http://www.flickr.com/photos/11977495@N06/sets/
1952 COE
1952 3100
1953 3100
1950 6400
1951 Suburban
Z
ZB3
Offline
Z Offline
Well I went down and got a grade five bolt and behold I have one of them out. Thanks for all of the help. You guys are great. Some day I may get this truck on the road yet. Thanks, Wayne
Z
ZB3
Offline
Z Offline
The bushings are out! The bolt method worked on the front two. Since there were no threads left on the back two I had to carefully hacksaw a slice in the back two. Now I can paint the frame. Thanks all, Wayne
