2 members (homer52, Tronman),
113
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24253 12/05/2002 3:12 AM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | will this transmission mate up to any chey inline 6, are there better choices?? | | |
#24254 12/05/2002 5:55 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Yes and Yes Depends on what you want to do.
#24255 12/05/2002 6:50 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | What are you mating to? The SM420 fits the bell housing for the 216,235,261 and early 230. The later model SM465 is a bigger box. The bell housing for this one requires a larger center hole, but the older housing can be machined to fit. For more info go to Nowak tranny page
Fred 52 3600 69 C-10
#24256 12/05/2002 4:24 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Nowak??? I thought it was Novak :p
#24257 12/05/2002 5:28 PM | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Thanks for the link to Novak. Great info source for the SM420 and other trans. For a 55 year old design, still a good trans. GM used it in trucks with 230/250/292 I6 and V8s through '67. I knew the 420 was sought after by jeepers and other off road/mud runner types. I had the original one in my '50 3/4 ton pickup behind a 307 SBC. That 2-piece driveshaft with front half torque-tube was strange though. I couldn't stop mine from leaking around the seal.
Professional Novice
#24258 12/06/2002 4:04 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Frank50,
Check my above homepage for how I solved the leaky torque tube problem. When I get mine back together, I hope to lose most of the kitchen ware. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#24259 12/07/2002 4:16 PM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | I would like to keep the stock drive train and either use a small block 350 or a modern inline 6 as in 70's nova | | |
#24260 12/07/2002 7:47 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | If you decide to use the SM-420 with a newer engine, (which may have the newer bellhousing, the one with no crossmember under it); you could get a piece of 5" XX wall steel pipe, about 3/4" thick and have it machined down to fit the opening and press-fit on to the SM-420 bearing retainer. I have had this done, but it was several years ago, so I'm not sure about the actual dimensions.
GM Truck, four speed standard transmissions. Built by Muncie. Installed in: 1947 - 1967 Chevrolet and GMC trucks up to 2 1/2 ton. Model: SM-420 - Bearing Retainer/Bell housing opening size - 4 11/16" Gear Ratios 1 - 7.06
2 - 3.58
3 - 1.71
4 - Direct
R - 6.78
Oil Capacity 5 1/2 pints
Installed in: 1968 - 1991 Chevrolet and GMC trucks up to 2 1/2 ton. Model: SM-465 - Bearing Retainer/Bell housing opening size - 5 1/8" Gear Ratios 1 - 6.55
2 - 3.58
3 - 1.57
4 - Direct
Length - 12"
*** GMC ***
#24261 12/07/2002 7:58 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | There are a variety of 420 transmissions that were used from 55 up that have a rear output yoke for the open type drive-line.Some have a flange and a park brake and drum assembly on the rear of the tranny with an open driveline.
