2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#24253 12/05/2002 3:12 AM
1 Offline
will this transmission mate up to any chey inline 6, are there better choices??
#24254 12/05/2002 5:55 AM
Yes and Yes grin
Depends on what you want to do.
#24255 12/05/2002 6:50 AM
What are you mating to? The SM420 fits the bell housing for the 216,235,261 and early 230. The later model SM465 is a bigger box. The bell housing for this one requires a larger center hole, but the older housing can be machined to fit. For more info go to Nowak tranny page
Fred
52 3600
69 C-10
#24256 12/05/2002 4:24 PM
Nowak??? I thought it was Novak :p
#24257 12/05/2002 5:28 PM
Thanks for the link to Novak. Great info source for the SM420 and other trans. For a 55 year old design, still a good trans. GM used it in trucks with 230/250/292 I6 and V8s through '67. I knew the 420 was sought after by jeepers and other off road/mud runner types. I had the original one in my '50 3/4 ton pickup behind a 307 SBC. That 2-piece driveshaft with front half torque-tube was strange though. I couldn't stop mine from leaking around the seal.
Professional Novice
#24258 12/06/2002 4:04 PM
Frank50,
Check my above homepage for how I solved the leaky torque tube problem. When I get mine back together, I hope to lose most of the kitchen ware.
#24259 12/07/2002 4:16 PM
1 Offline
I would like to keep the stock drive train and either use a small block 350 or a modern inline 6 as in 70's nova
#24260 12/07/2002 7:47 PM
If you decide to use the SM-420 with a newer engine, (which may have the newer bellhousing, the one with no crossmember under it); you could get a piece of 5" XX wall steel pipe, about 3/4" thick and have it machined down to fit the opening and press-fit on to the SM-420 bearing retainer. I have had this done, but it was several years ago, so I'm not sure about the actual dimensions.
GM Truck, four speed standard transmissions. Built by Muncie.
Installed in: 1947 - 1967 Chevrolet and GMC trucks up to 2 1/2 ton.
Model: SM-420 - Bearing Retainer/Bell housing opening size - 4 11/16"
Gear Ratios
1 - 7.06
2 - 3.58
3 - 1.71
4 - Direct
R - 6.78
Oil Capacity
5 1/2 pints
Installed in: 1968 - 1991 Chevrolet and GMC trucks up to 2 1/2 ton.
Model: SM-465 - Bearing Retainer/Bell housing opening size - 5 1/8" Gear Ratios
1 - 6.55
2 - 3.58
3 - 1.57
4 - Direct
Length - 12"
*** GMC ***
#24261 12/07/2002 7:58 PM
There are a variety of 420 transmissions that were used from 55 up that have a rear output yoke for the open type drive-line.Some have a flange and a park brake and drum assembly on the rear of the tranny with an open driveline. cool
