7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible), 82 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
I have a question for anyone that has switched to a dual master cylinder. How did you plumb your brake light switch in?
I am using 1/4" brake line to the rear wheels and I am having trouble finding a tee connector that will allow the 7/16" X 20 thread for the brake line and have a 1/8 NPT thread for the brake light switch.
I can't change the size of the brake line at this point, but I could change the brake switch if I need to.
Does any one have a resource I can use?
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
Bill:
I use Pure Choice Motor Sports for brake lines and fittings. You can call them and they will advise you as to what you need.
http://www.purechoicemotorsports.com/index.cfm
~Jim
3B Offline
Hy Bill Schickling, Try weatherhead p/n 652X4, hope that helps.
Thank you both for the information. It looks like purechoice sells a nice set of switch and tee.
I believe the 652X4 tee is just what I need.
Joe,
I had seen those in the catalog. Do they mount on the floor?
Bill Schickling
My web page
