| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | My day for questions I guess!
I recently installed a rebuilt steering box in my 56 3100... steering improved for about a week but then it developed a lot of play - like 25 - 30% - especially to left. Made the usual adjustment on the side worm screw and the front end and arms are all OK.
Is there another adjustment somewhere? Anyone ever get a bad rebuilt?
Thanks! | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Larry, There is a bearing adjustment on the bottom end of the box but I doubt that is going to solve the problem. If the tie rods and the other components are tight and it has that much play, there is something wrong in the box. It's entirely possible that it was rebuilt with a questionable part that has now failed. Fred
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Larry,
I think the adjustment Fred is speaking of is the bottom bearing preload for the worm gear. If this were the cause of your problem, it might be noticeable in the steering wheel itself. A gross misadjustment here would force the whole shaft up and down...trying to shove it into your chest or pull it away from you. As you turn the wheel back and forth, you would see any gap between the wheel and turnsignal cup get larger, or diminish. I think this is how it works.
Stuart | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks for the info Fred & Stuart... I'll get her to the garage and do some additional checking. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Good Luck Larry and let us know what you find. | | |
