| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Guys needsome help I was told that a 17x7 wheel with 3.5 bs on front, and 17x11 with 6.75 bs with 235 45R 17 front, and 305 45R 17 back tirs would fit under a stock 1951 chevy truck, does anybody know for sure? If not could someone give me some advise on wheels and tires. I would like to get 17" wheels, and widest tires posiable. thanks
Tony Jacques
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The front baskspace is right on, the rear seems a little deep, and will most likely rub the bedsides, unlees it's been tubbed. The tire sizes themselves will physicly fit, though if you're still running the stock style running gear, they will be underrated for the load. You will have to run higher tire pressures to compensate for the extra loading.
Bill Burmeister | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | longbox55 I am going to be running a 9" ford rear end. With a 4 bar coil over suspension. So you are saying that the tires for sure will fit, what about the 17" wheels. I am with you the back seemed a little deep to me to. Do you know what width rear end I need?
Tony Jacques
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The rims should be fine. As far as width, you might do a search in the Engine and Driveline forum. I know the subject came up there several times, so you should be able to get a more accurate dimension there. With the lighter suspension components, the load issue isn't going to be as much of a concern. I only mentioned it from experience with an otherwise stock truck that a customer wanted a low profile tire on (245/45/16 on a '72 C20). We had alot of issues with tire failures due to the insufficient load range.
