1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#24166 08/13/2003 3:33 AM
Junior Member
Junior Member
Yes hey stovers, what up I got a 63 fleetside truck with 283 3speed all stock no rebuild on engine runs great but I have dual exhaust on it and on the right bank when engine is hot or cold there is always smoke coming from the right side and that side is always colder than the other side is.Do you think the cam is bad making the valves not open right can somebody help?
#24167 08/13/2003 5:38 AM
seems like it could be a number of things - do a compression test and even a leak down test - see how long it takes each cyl to pump up compared to others
#24168 08/13/2003 5:48 AM
What color is the smoke?
Black= too much fuel
Grey/white= oil or antifreeze depending on the smell.
I am betting it will be rings or vavle guides/seals
#24169 08/13/2003 12:50 PM
k10 Offline
Do a quick check to see if all the plugs are the same type and gap. Maybe someone only got half done with a tuneup.
