| | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24166 08/13/2003 3:33 AM | Joined: Jun 2003 Posts: 17 Junior Member | | Junior Member Joined: Jun 2003 Posts: 17 | Yes hey stovers, what up I got a 63 fleetside truck with 283 3speed all stock no rebuild on engine runs great but I have dual exhaust on it and on the right bank when engine is hot or cold there is always smoke coming from the right side and that side is always colder than the other side is.Do you think the cam is bad making the valves not open right can somebody help? | | |
#24167 08/13/2003 5:38 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | seems like it could be a number of things - do a compression test and even a leak down test - see how long it takes each cyl to pump up compared to others
Bill | | |
#24168 08/13/2003 5:48 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What color is the smoke? Black= too much fuel Grey/white= oil or antifreeze depending on the smell. I am betting it will be rings or vavle guides/seals
#24169 08/13/2003 12:50 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Do a quick check to see if all the plugs are the same type and gap. Maybe someone only got half done with a tuneup. | | |
