Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (46 Texaco, Bill Hanlon, FAST55, 50Chevy3100, carbking, NorCal52Suburban), 141 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
Junior Member
Junior Member
1 Offline
I am replacing my inside door hanldes. I got the passenger side off and replaced, but my drivers side will not budge! I took the screw out and it still will not come off. I have sprayed in with WD-40 and even hit it with a hammer, IT WON"T COME OFF......HELP!!!!!!
You might try to give it a strong blow straight on. That could knock some rust loose. I'm sure someone with experience with obstinate door/window handles will chime in soon.
~Jim
If you can get your eyeball around under there,or a mirror,,take a look and see if there isnt a second screw holding it on.
Or ,,,stick a narrow slotted screwdriver up there to see if theres another screw.
Some of the orig. ones had two screws,,one to lock it onto the shaft,,and another one to keep the first one from backing out.
Good luck,
Marty
Oh yeah,,,,the new "just like original" ones from the vendors wont have the second lock screw,,put a drop or two of Loc-Tite on the threads or keep a screwdriver in your glovebox.
Marty
WD-40 doesn't work that well as penetrating oil; try PB Blaster or Kroil for obstinate part removal.
Junior Member
Junior Member
1 Offline
If I can't find another screw holding it, I'm going to try this pent.oil that we have at work on it.
Got a Dremel tool? Cut a slot in the old handle and crack that baby off.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Junior Member
Junior Member
1 Offline
Got it off. It had a second screw in it.
I wirked on mine for a week before i realized there was a second screw inside...who'da thunk it!
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
I use Kroil, you can order it on-line. Best thing around!
1937 Chevy 1/2-Ton
