| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Ok this one is probably going to upset a few people out there, but here it goes, I have a straight axle from a 1/2 54 GMC can it be swapped to my 52 1 ton in the front? The reasoning is to switch to new disc breaks and yet continue to us the stock suspension? It looks like everything lines up. I am concerned about the spring width as it looks like the 1/2 was slightly larger than 1 3/4" and the other looks to be 2". Do I need to swap out the springs too? otherwise I would guess it would work without any hitches, but I figured I would ask the experts. This would allow me to go to a 5 lug and get disk brakes.
Thanks | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Go for it!
I think the steering box is the same on both a 1/2-ton and 1-ton so it should be easy to adapt the steerng related parts.
I don't know about the difference in spring width, but I'd try to make the 1/2-ton axle fit the 1-ton springs perhaps by moving the u-bolt holes or perhaps drilling them out larger.
Springs, shocks, steering and brakes are the only places the axle touches the truck, and springs the only one that might be a challenge.
The 1/2-ton axle is not as strong as the 1-ton so your max load capacity will be reduced by that change.
The swap to disk brakes will probably improve your braking, but not improve it to current 1-ton specs. Also the disk brake conversions, either 5-lug or 6-lug will mean using wheels that are likely not 1-ton load rated.
If you won't be hauling 1-ton loads I don't see those issues as significant. But remember you no will no longer really have the original 8800 weight rating. If that doesn't matter go for it!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | ok , here it goes. i'm not an expert, but i will share what i have learned. the spring center to center on all models is 26 13/16". so the axle will fit between the springs. the 1 ton springs are 2" wide and the 1/2 ton springs are 1 3/4". so the mounting pad u-bolt holes and the shock plate on the axles will be different, and the 1 ton u-bolts are 9/16" dia. while the 1/2 ton are 1/2 " dia. you probably can't use the 1 3/4" springs without changing the spring end and shackle perches on the frame [different width].. also, the model 3100 and the model 3600 have a spring length of 38", while the 3700 through 5700 models spring length is 40". i hope this all helps. garyg
our garage is a non-profit organization
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Another option, there's a thread on here on adapting disk brakes to the 1 ton axle. Might be worth looking at. here's the link http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=012145#000000
Bill Burmeister | | |
