3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#241339 09/26/2007 7:57 PM
Is there anyone out there bouncing around the forums that knows how the windshield wiper on/off switch mounted on the dashboard is connected to the vacuum windshield wiper motor mounted under the dash? I'm tinkering with a '53 6400 and its first road test is imminent. However, the connection for the wiper motor/switch has rotted and turned to dust from the truck sitting in a field for 15 years. I'd kind of like to have wipers, even if they are slow. Rain-X will only do so much. Chances are I'll wind up making the connector since there's no challenge in going out and just buying one. I was hoping someone might be able to help a wet behind the ears bolter, so any guidance is appreciated. Thanks!
When at first you don't succeed, get a larger hammer.
1953 Chevrolet 6400 Flatbed
#241340 09/26/2007 8:19 PM
The knob/switch has a wire link to the wiper motor to direct vacuum to the motor (very simple system).
If you are missing the link,you can make one up using some thin welding rod.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#241341 09/26/2007 9:28 PM
Yup, wire rod.
Its unlikely that the vacuum motor still works, but you could try it.
Paint & Body Shop moderator
#241342 09/26/2007 10:48 PM
Maybe I'll get lucky and not have to re-build the motor. I seem to remember the first time we started it up that the wipers flapped around a bit, but maybe it was a hallucination. At any rate, thanks for the help, I appreciate it!
#241343 09/26/2007 11:54 PM
You can reach up and move the lever the wire rod runs to to see if the wipers work before you bend up a new rod, that way you'll know when you have the rod right. The wiper on-off lever has a grommet to reduce the hole in it to the rod size--about 3/32 to 1/8. The rod ends have a double 90 degree bend to stay in place. If the motor doesn't work, think FICKEN.
Evan
#241344 09/27/2007 4:51 AM
You might want to look around in the cab. I found my wiper link under the floor mat when I got my truck.
#241345 09/27/2007 8:43 AM
Try adding a few drops of light weight oil in the input side of the wiper motor this will soften up the seals and improve wiper performance. Rebuild service is avail for the motor. http://www.wiperman.com/ he does nice work.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#241346 09/27/2007 10:10 AM
I have a wiper control out of a '54 6400 if you need it.
My Trucks
Stuff I Collect
#241347 09/27/2007 4:24 PM
I'll have to give the lightweight oil trick a shot. With the condition of the rest of the rubber on the truck, I'll be astounded if the motor holds up. I thought about converting the wiper system to 6 volt electric so I've got more speeds than incredibly slow and off, but I'm not sure. Hopefully what I've got will get me by for the remainder of the summer/fall. Guess we'll see. I'll have to post some pictures of it in the gallery, the truck's a fine piece.
#241348 09/28/2007 3:57 AM
Jake, Fiken rebuilt my wiper motor and it works great. You can also get the grommets for the control arm from Jim Carter if you need to replace them.
#241349 09/28/2007 5:35 AM
I'll have to think about sending it in and having it re-done. I found a motor in a box of old truck parts I bought awhile back that works for now, but I have a feeling it's days are numbered. Anyone know how much getting one re-built might cost? Or would it be more prudent to pursue a 6 volt electric wiper conversion?
#241350 09/30/2007 2:38 PM
I would go with a 6 volt electric over vacuum.The vacuum wipers slow down under engine load , just when you need them the most.
Wanted Good Woman:
#241351 09/30/2007 3:46 PM
Where is the best place to buy a 6 volt wiper motor?
Chris
48 1 Ton
#241352 09/30/2007 9:43 PM
I recently installed a 12volt wiper motor from jim Carter. Now the wipers are off/extremely slow/slow. I thought they would go faster, but at least the origional linkage won't get too stressed.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
#241353 10/01/2007 4:26 AM
Yeah, when I was hanging upside down under my dashboard like a monkey getting the wipers to work again I noticed those linkages left alot to be desired. Was the 12 volt motor from Jim Carter reasonably priced?
