5 members (WICruiser, 55shaker, Oswald, Bill Hanlon, 1955 1 Series), 178 guests, and 1 robot.
Topics128,263
Posts1,058,348
Members48,485
#241024 09/20/2007 3:11 PM
does any one know where i can get the frame dimensions for a 72 GMC 3/4 ton truck so i can check the frame aligment.. thanks
#241025 09/20/2007 3:15 PM
The service manual?
A body shop with a frame machine?
•1952 Chevrolet 3800 pickup
---All pictures---
#241026 09/21/2007 2:22 AM
I don't have an answer, but if you find the information I'd like to have it also. I have a '72 C20 frame out back and would like to be able to check it out.
#241027 09/21/2007 3:47 AM
the assembly manual is what you want for detail, but if you want to see if things are the right shape, just measure diagonals everywhere, like front left tip to rear right tip compared to front right tip to rear left tip ... do end to end, front to first crossmember, to second, to third, then back to first, etc
if one diagonal measurement is much off it's counterpart, it's wracked, if they all match up well, you're ok
#241028 09/21/2007 7:30 PM
i know the front frame horns are bent, as i can see the front bumper does not line up , and want to get it centered again, but dont think its bent back as far as the front crossmember,,
