| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | I have a 54 chevy pickup and I want ot lower the front end and keep the straight axle. I don't want to drop it much 2" or so. What is the best way to go?? Dropped axle or springs?? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | The springs are less $$ and less work. Usually a few hours. Drop axle= more $$ more work. Iv done em both. Check out my '54s in the gallery. Marty Flores' deluxe 54 panel and 54 5 window pickup. 4" drop axle on the panel,,mono-leaf springs on the pick up. | | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | Nice!!! I'll probably go with the springs.Thanks for the info. Where did you get the 4barrel intake for the panel. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I don't have first hand experience on this, but I've heard a few members here complain about the ride of the mono leafs. Maybe delux54 can comment on that as he has done it both ways. | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Got front monoleafs on my daily for many years and love 'em. Takes a while before they break in. They never wear out or bottom out and can handle more stress than the stock springs. Jim Durant makes them for many models and supplies all the vendors. He is local here in s-ca and very good to talk to by phone. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Just let air out of the tires.... | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | remove a few leafs from the stockers it's free and easy. 2" should be had with maybe 2-3 leafs?! | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | That would be the cheapest way, but gives a stiff ride and more bottoming out. On trucks I would try to preserve the load specs. | | | | | Joined: May 2005 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 65 | Another option are the 3" drop 2-leaf front springs from Posie. Don't know anyone who has tried them though. http://www.speedwaymotors.com/p/5839,1111_Classic-Ford-and-ChevyandGMC-Pick-up-Front-Leaf-Springs.html
1950 Chevrolet 1300
| | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | I had a poor experience ordering rear leaf springs from Posies earlier this year for my coupe. They could not get the center pin location right and seemed to rather specialize on ford hot rods and knew little to nothing about Chevy specs. They shipped two separate sets of springs that didn't fit. | | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | Thanks for the information. Not sure what way I will go? Tried to post some pics but I guess I haven't figured it out yet ! As soon as I do I will post pics of my truck. | | | | | Joined: Sep 2007 Posts: 12 New Guy | | New Guy Joined: Sep 2007 Posts: 12 | Thanks for the info. I'll probably try removing some leafs because the truck is leaning to the drivers side anyway. I now have another problem! I am looking for a slip yoke to fit a 3 speed tran from 55-64. It has to be 1 3/16 with 16 teeth. I pulled the tork tube out & put a newer rear end in my 54 to get hwy speeds & all I need to get a drive shaft made is the yoke.Anyone outthere have one or know where I can get one? | | |
