3 members (TUTS 59, WICruiser, 1 invisible),
125
Mod | | | Forums66 Topics128,090 Posts1,056,382 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 16 New Guy | | New Guy Joined: Jun 2006 Posts: 16 | Can anyone tell me where I can buy good shocks for my 3804?
Charles | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I didn't think 3800s had shocks. You might get a better response if you listed a year model, too. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | My 1951 3804 has front tube shocks that can be found at NAPA, No shock on rear end. My 1948 3804 parts truck has lever action shocks on front, none on rear. I do not know who sells the lever action front shocks. Jerry Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 51 1 Ton has tube shocks up front and none in the rear. I bought my front shocks from Jim Carter. It is interesting to note that mine has shock mounts on the rear axle but not on the frame. I would guess that this is because the 3/4 Ton had shocks and used the same axle housing. | | | | | Joined: Jun 2006 Posts: 16 New Guy | | New Guy Joined: Jun 2006 Posts: 16 | Thanks for the replies, I have a 1948 chevy registered as a 47 with 9 ft. bed. Yesterday I noticed the rear housing had mounts but not the frame anywhere. So guess it don't need them back there. Again Thanks | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Double acting rear shock absorbers were a regular production option for the 3800. I'm sure you could make something work if you think you need them. | | |
