5 members (J Lucas, Brian Moore, Pete1946, Otto Skorzeny, Hotrod Lincoln), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#24035 04/20/2004 1:29 PM
i had a back tire off and the engine idling at the same time on my '53 3100 and the wheel was slowly rotating forward.
is this a clutch problem?
what would be my best approach to adjust anything?
#24036 04/20/2004 2:48 PM
Doesn't sound like a problem to me, assuming the trans was in neutral while this was happening. The gear oil in the trans is stiff enough, especially when cold, to transfer a little motion from gear to gear due to shear action between the gears. Sort of like a torque converter.
The shear action is not efficient enough to do much work; you can stop the wheel or brake drum easily by hand, I'd imagine.
Joe
#24037 04/20/2004 3:00 PM
May I also add, its a bad idea to have an engine running when vehicle is on a jackstand? Cars can shake off a stand and fall.
be careful out there.....
wink
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#24038 04/20/2004 6:00 PM
Quote
chip
Chip, I hope you didnt have a problem with this, too! eek
Fred
52 3600
69 C-10
#24039 04/20/2004 8:01 PM
Chip, I had decided not to commment on your post, but I've been thinking about it and I have to say...
If your jackstands and the surface on which they sit are not strong/level/hard enough to support an idling vehicle, they are not adequate to work under.
We do things under our trucks that will impart more energy to the truck in more dangerous directions than a idling motor. I wouldn't get under the truck at all if I didn't trust the stands to hold it while it was running.
Joe
#24040 04/20/2004 9:52 PM
H Online: Content
Yes, the trans lube will transmit enough torque to spin the driveshaft, but pretty slowly under normal circumstances. The Model "T" would actually roll forward in neutral if it was started with the trans grease cold, so some people would jack up one rear wheel before cranking the engine on a cold morning. Otherwise, the things could run over the person out front turning the crank!
#24041 04/21/2004 1:41 AM
i can't beleive i learned something about my van that didn't translate into 2 weekends spent crawling around under it trying to fix it!!
thanks
by the way it was sitting on a stand and the jack itself, and i would never get under there while it was runnin!!
