| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | '65 Chev LWB 292 6cyl, 4 speed. Any ideas on how to get better gas mileage? different carb? Best way to do power steering conversion? Power brakes or at least 2 port master cyl conversion? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | mileage-overdrive, steering-REZ kit+68-87 power strg box, brakes-73-87 C10 booster fits well, use 67-70 drum master, the front & rear lines will split easily at the TEE under the engine on the #1 crossmember | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | For gas mileage check the basics. Timing, vacuum advance & carb condition. Like fleetside says, O-drive or change rear ends to a higher gear ratio. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
