5 members (Phak1, Hanks custodian, walter74, Charles in CA, baldeagle), 164 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#239948 08/28/2007 8:00 PM
Junior Member
Junior Member
'65 Chev LWB 292 6cyl, 4 speed.
Any ideas on how to get better gas mileage? different carb?
Best way to do power steering conversion?
Power brakes or at least 2 port master cyl conversion?
#239949 08/28/2007 8:53 PM
mileage-overdrive, steering-REZ kit+68-87 power strg box, brakes-73-87 C10 booster fits well, use 67-70 drum master, the front & rear lines will split easily at the TEE under the engine on the #1 crossmember
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#239950 08/28/2007 11:12 PM
Riding in the Passing Lane
For gas mileage check the basics. Timing, vacuum advance & carb condition. Like fleetside says, O-drive or change rear ends to a higher gear ratio.
1972 Chevy c10 Cheyenne Super
