| | | Forums66 Topics128,114 Posts1,056,605 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | I have a question for anyone that might be able to help. After searching the site I cant seam to find where the stop light switch should go on my 39 1/2 ton. Getting close to putting it on the road but i think i should have brake lights lol. anyone have some info or a picture of the location and how its mounted?
thanks matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Did your 39 ever have stop lights and signals ? I would plumb a pressure switch into the brake line from the master cyl.Wire it with fused power in and the other lead to your stop lights.If you have a signal switch (like a Signal Stat/Napa 900),one lead on the switch is set up for stop lamps.Signal lamps in the rear and stop lamps are the same.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Fatboy0169, I just looked it up for you.The Black/Grey wire on the Signal Stat model 900 and 905 is for your stop light switch.
| | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | i doubt it had signals but would all cars have break lights?
| | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | i bought a brake light switch from jim carter that is supposd to go on the toe board.. im just not sure where
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | It's on the master cylinder, goes on the side. Here's American Classic's pic of a master cylinder I can send you a shot of mine if you need it. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Now that I look at Jim Carter's you must have got the mechanical type. You can put it put it anywhere that makes sense. You're going to have to rig it just right so it hits at the right time. I'd recommend you just get the hydraulic as it's a breeze to install | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | fatboy0169 - If you are interested in installing the correct light switch like the original one, than it will mount on the master cylinder as InMy40s states. Your master cylinder looks like the one in his picture, that he has posted for you, and it screws into the 1/8" pipe thread hole where the small brass plug appears at the back of the master cylinder on the left side (as it is mounted). That is the correct way and the way it came from the factory. You run a hot wire to one side of the switch and from the other terminal, you run a wire to the brake light. When you step on the brake, the pressure increases inside the master cylinder, to stop the vehicle, and the pressure also activates the switch. This called a brake pressure switch and it is still available from most neighborhood auto supply stores. It was used on all of the cars and trucks up ito the 40's, some into the 50's. Again, it is a 1/8" pipe thread brake pressure switch. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | thanks i guess i ll return the mechanical and get the pressure type lol...just want to thank all the guys on here for the help im sure i will get needing... thanks again
| | | | | Joined: Dec 2002 Posts: 3,444 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,444 | OR, you can just rip out all that stock stuff, and install an underdash pedal hanger, with the master cylinder outside the firewall!!
then you can use the mechanical switch.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Originally posted by InMy40s: It's on the master cylinder, goes on the side.
Now if you were to look at a master parts book you guys could see that both are correct a mechanical switch is screwed to the toe board but they could have a hydraulic switch (common on most smaller trucks) Mike | | | | | Joined: Jul 2005 Posts: 2 Junior Member | | Junior Member Joined: Jul 2005 Posts: 2 | I have a '56 Chevy truck type mechanical lever switch screwed to the bottom of the toe board under the brake pedal arm instead of the hydraulic pressure switch. It's been good for over a decade. | | | | | Joined: Jul 2005 Posts: 2 Junior Member | | Junior Member Joined: Jul 2005 Posts: 2 | Sorry. That's in my 40 GMC that's in the gallery under John Shipman. | | |
