| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 9 New Guy | | New Guy Joined: Nov 2006 Posts: 9 | I am replacing the brake lines on my '57 6400 and I was planning to reuse the old brake line fittings. I was wondering what I can use to clean the fittings. I can use a wire brush on the out side but I wanted to get the inside clean also. Any suggestions is appriciated. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | rifle brush, pipe cleaner, strip of shop rag torn & wadded up | | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Rifle brush, chuck in drill, submerge fitting and brush in solvent, run drill until clean. Fast , Easy.
But, hold the fitting with visegrips so it doesn't spin and beat your fingers up. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I hate to be the doom sayer here but ya got about a 90% chance that the inverted flare in the old fittings are probably crushed or distorted from the old Steel lines. There is a real good chance that if you put new lines on your old fittings your gonna end up with a leak. Do as you wish but if it were me I would also replace the brass. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm going to go with Denny on this. New fittings are cheap. About the only real reason for trying to save an old one is if it's an odd size fitting that isn't available on the aftermarket. Later GMs are bad about that on the MC and Prop Valve. If you do want to try to save them, the methods mentioned will work, however, I would use a 6 point socket rather that vise grips to hold it. Less change of damaging the hex. Also, run a thread chaser or die over the threads to clean them thouroughly.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 9 New Guy | | New Guy Joined: Nov 2006 Posts: 9 | Ok thanks for the suggestions. I found another discussion on the board about fitting and I will try to buy new ones. | | |
