2 members (homer52, Tronman),
113
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 4 New Guy | | New Guy Joined: Aug 2007 Posts: 4 | I AM LOOKING TO DECODE VIN ON MY TRUCK I HAVE COWL TAG THAT READS GENERAL MOTORS OF CANADA LIMITED I HAVE ONLY FOUND DECODING INFO ON US TRUCKS . HERE IS INFO ;MODEL;14-33 SERIAL;9143304067 ENGINE;T1994110 BODY SERIAL;3775 TRIM;773 PAINT ;933 ANY HELP APPRECIATED THANKS IN ADVANCE , TOM | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the shop Tom - no need to SHOUT, yer not that far away 9143304067 = 9 - 1939 14 - 3/4T 33 - pickup 04067 is the 'sequence' or id number the rest of the numbers will be hard to find any info on unless you get hold of some odd factory books that happen to have them, records of CDN codes seem to have been neglected .... oh, and it's a Chevy, as opposed to a GMC or Maple Leaf Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy TOMMYDALE1950, Your serial number breaks down as follows 9 - year 1939 1433 - chassis w/cab 133" W.B. rated 1 ton 04067 - sequential unit number I can't answer what the rest of the numbers mean, but someone probably can, hope that helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 3B - 43 is the cab/chassis, 33 is a pu, and I thought 1500 was the 1T 'rated' .... 1938 was when they started the "modern" numbering pattern, and there isn't even a 1400 series listed there, 3/4T to 1.5T were all 1500 with different model numbers, but I think 39 and later they went to 14, 15, 16 series scheme
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy red58 and guys, My reference is parts catalog no. 330, 1938-1951. According to that catalogue there were no 3/4 ton rated trucks in 1939 Chevrolet production, 1431 was a chassis w/flat face cowl, 1432 was a chassis w/cowl, 1433 was a chassis w/cab 1435 was a panel delivery, all rated at 1 ton according to this catalogue, I can only quote what is in front of me, hope that clarifies. | | |
