8 members (cmayna, 2-Ton, 55shaker, Mike Roache, Gdads51, mk72, Opelika Tom, 78buckshot),
102
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23884 03/22/2003 6:52 PM | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | I just received my V8 crossmember and tranny crossmember (with motor mounts and tranny mount) from Chevy Duty. No instruction sheet of any kind, just parts thrown in a box and mailed. For $150 you'd think they'd include some basic instructions, but no. Anyway, I know how it all goes together, I just don't know WHERE EXACTLY along the frame rails they mount! Can anyone who has done this swap (350 V8 into 1950 3/4 ton pickup with T400 tranny) shed some light on this? Since my cab is removed from the frame right now for restoration this is the perfect time to drop in the new motor, I just need to know exactly where the crossmembers mount, measured from the front end of the frame rails possibly? Any replies are appreciated! Tom | | |
#23885 03/22/2003 8:09 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Tom , it may be best to have the cab sitting on the frame . This way you can check your distributer to firewall clearance in a real world situation.You can gently drop on the cab after the engine and mounts are mocked up to ensure all is well before finish welding or bolting in the various crossmembers. You also have to make sure the tranny clears the cab floor or firewall and that the engine downward angle is not so severe it upsets the U-joint angles.You can do it by measuring for sure, but the mock up may save time money and scratched paint in the long run. | | |
#23886 03/23/2003 1:24 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I'll go out this evening and take a few pictures and measurements for you. I'm using a small distributor "MSD" but I'll give you water pump to radiator measurements, Back of the block to the firewall and some other measurements.
I'm running a 350 small block and a turbo 350 transmission.
Joe
Joe
#23887 03/23/2003 4:09 PM | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | Thanks Tony and Chevy1! I know this is critical and I want to get it perfect. Chevy1's measurements would give me a great starting point, then I could check it using Tony's method. Thanks again! Anybody else out there with a 350/t400 set up that can throw some measurements my way would be GREATLY appreciated! Tom | | |
#23888 03/23/2003 7:46 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Hi,
I took this rough measurements for you. My camera is charging but I will send you a few pictures directly to you for later reference.
Measurements:
Vertical radiator support to front of passenger side head..........11 3/8"
Back of passenger valve cover to firewall...7/8"
Firewall to back of distributor......1 3/4"
Water pump pully "face" to radiator ..... 3"
Remember I'm running the smaller MSD Distributor
My truck is a 1950 Chevy 1/2 ton with a 350, 350 automatic..
Joe
Joe
#23889 03/24/2003 1:17 AM | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | Thanks a heap Joe! I really appreciate the measurements, and from the looks of them it appears it's a tight squeeze! Tom | | |
