2 members (tclederman, tesa), 56 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,430
#238413 08/05/2007 3:01 AM
I saw a truck today ( I think it was a 51 GMC) that had a rubber block on the metal bar that is attached to the brake pedal where it sticks through the firewall. The rubber piece was about 2"x1"x1".
It had a hole in the middle for the metal bar to go through.
It acts as a stop so the metal bar doesn't strike the underside of the firewall when the brake pedal is released.
Does anyone one know who sells this, and what it is officially called?
My dad always told me, "Don't force it, get a bigger hammer".
#238414 08/05/2007 3:23 AM
The various vendors sell this for the clutch pedal, not the brake. The brake pedal uses the stop in the master.
1951 1 Ton Completed
#238415 08/05/2007 3:59 AM
Truckernix,
Oops! You're right, the metal bar I was looking at is attached to the clutch pedal.
Thanks.
#238416 08/05/2007 5:35 AM
I always just cut a few washers out of the sidewall of an old tire, and made a slit in them so they could be slipped over the clutch pedal shaft.
