0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I saw a truck today ( I think it was a 51 GMC) that had a rubber block on the metal bar that is attached to the brake pedal where it sticks through the firewall. The rubber piece was about 2"x1"x1". It had a hole in the middle for the metal bar to go through. It acts as a stop so the metal bar doesn't strike the underside of the firewall when the brake pedal is released.
Does anyone one know who sells this, and what it is officially called?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The various vendors sell this for the clutch pedal, not the brake. The brake pedal uses the stop in the master. | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Truckernix,
Oops! You're right, the metal bar I was looking at is attached to the clutch pedal.
Thanks.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I always just cut a few washers out of the sidewall of an old tire, and made a slit in them so they could be slipped over the clutch pedal shaft. Jerry
