0 members (), 85 guests, and 2 robots.
Topics128,095
Posts1,056,067
Members48,433
does anyone know the screw size for the ad split window stainless molding include the length please
1949 SUBURBAN
John,
Looks like they are 10-32 oval head phillips.
Overall length is 1 1/8",threaded part is 1 inch.
Longer is NO Good,It will dent the stainless from the back side,Dont Ask. eek
If you can only get longer ones,cut them down wink
Regards,steve sr.
I just installed mine and used #10-32 oval heads x 1 1/8" long per the previous post. I found some stainless screws at my local hdwr store and put a nut on em and ground them to length - then removed the nut to clear the threads. I think I installed those clips correctly (but I ain't sure) I used them to cover the gap between the RH and LH inner windscreen trim (upr & lwr).
Anyone have a picture of these installed correctly?
Regards,
I had same thing happen. Glass man put wrong screws in! Buying one from fellow stovebolter. Parts wanted worked great! So quetion is is 10 32 1 1/8 correct size or do they need ground down.
The above post has description and measurements taken from the divider on my 50 1ton parts truck that was Original and Unmolested prior to becoming mine grin
Regards,
Steve Sr.
thanks guys
1949 SUBURBAN
Those little clipss do cover the space between left and right windshield trim. I think GM used this detail in alot of their cars too.
1951 1 Ton Completed
