| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | Hi Guys, hope you can help me here, i have just pulled a 1955 task force series truck from a garage here in england, the truck does not have any paperwork (title) with it and the vin number is missing from the 'A' pillar i have found a number that looks something like this H255 AO53804 On the top of the drivers side front frame rail (just in front of the steering box), now someone has told me that the chassis number was also stamped on top of the frame rail underneath the cab. do any of you guys know if this is true, before i lift the cab off the frame. hope you can help limey dan | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The # that you found is the VIN, the same # is also stamped under the cab, too. From what I can tell from the # you've got, it's a 3100 from tha Atlanta plant.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | thanks longbox55 for the info,looks like the cab will come off just to verify the number. the truck does have a georgia windshield sticker, so you could be correct. thanks for the help limey dan | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pulling the cab just to verify a number you already have stamped in steel?? don't count on finding a number under the cab - 55 was when they started stamping the vin on the frame and it was inconsistant until 57 or later, some 55's didn't get stamped, some had one, same with 56 and 57, varied at different plants .... and not a matter of "could be" correct, plug the number in the vin buster Bill | | | | | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | thanks for your help bill, the truck is apart already and the cab is held to the frame with ziplocks, the number i got off the front frame rail seems to be correct but two of the last five digits are unclear, i just wanted to prove beyond all doubt that the vin# is correct. here in europe vehicles manufactured before 1973 do not need to pay for a road fund license (you guys call it 'license tags') a truck like the one i have with an engine size greater than 3 litres could pay $700.00 to be on the road in tax, and that's the reason to be exact with the vin# to prove it's year of manufactue, and to avoid the extortionate tax. thanks for your help Limey Dan | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Historically, we too have had problems with your government's taxation;-) but now we have problems with ours. At least your government now taxes on displacement rather than on bore alone, as they did for decades. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the last 6 digits have nothing to do with year of manuf, they're the sequence number, the first part tells the year: H = 1/2T 2 = 2nd series 55 = 1955 A = Atlanta plant 0[not o]53804 = 52,803rd truck made there [all 55 2nd ser no's started at 001001 at each plant] .... and I'd think a picture would suffice to prove it's pre-73!!!
Bill | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Not to be too persnickety, Bill, but the 1001 number was assigned to a truck, so it would be the 52,804th assembled there. You subtract 1000, not 1001. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  yer right, not persnickety Bill | | |
