2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 28 Apprentice | | Apprentice Joined: Jun 2007 Posts: 28 | I just got a 36 and the serial number on the firewall is FB59077. Well thats what it looks like. I am going through a title service and need to know if this is correct. I put it through the vin decoder and it doesn't reconize it.
I just ordered my resto kit and chevy could not confirm it was correct, they are still sending the kit though. any ideas? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Look on the engine, on a boss behind the distributor. Click on the "search" link under the "Post New Topic" button. Put VIN in the search box. After you read all of those put "title" in the search box. You'll find hours of reading on this subject.
| | | | | Joined: Jun 2007 Posts: 28 Apprentice | | Apprentice Joined: Jun 2007 Posts: 28 | engine was trashed before i got the vehicle. Only have one number on the firewall | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You'll need to contact your governmental titling authority & see what requirements they have. They might let you use the serial number, they might not.
| | | | | Joined: Jun 2007 Posts: 28 Apprentice | | Apprentice Joined: Jun 2007 Posts: 28 | i want to use the serial number the truck was registered to. I guess i can contact the OR dmv and find out the serial number they have on file for the plate. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The FB on the body serial number tells you that it is a 1936 half ton pickup. F=1936, B=half ton pickup. | | | | | Joined: Jun 2007 Posts: 28 Apprentice | | Apprentice Joined: Jun 2007 Posts: 28 | wow the dmv has no record of the serial number or the plate number. apparently they purge after 10 years and this truck hasnt has a plate since 72. nice! | | | | | Joined: Jun 2007 Posts: 28 Apprentice | | Apprentice Joined: Jun 2007 Posts: 28 | ok i took another look the serial is
5FB059077 | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by playboy: ok i took another look the serial is
5FB059077 Stick that number in the VIN Buster It tells you that it's a 1936 1/2 ton with a 112inch wheelbase built in Kansas City, MO.
