1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Apprentice
Apprentice
I just got a 36 and the serial number on the firewall is FB59077. Well thats what it looks like. I am going through a title service and need to know if this is correct. I put it through the vin decoder and it doesn't reconize it.
I just ordered my resto kit and chevy could not confirm it was correct, they are still sending the kit though. any ideas?
Ex Hall Monitor
Ex Hall Monitor
Look on the engine, on a boss behind the distributor. Click on the "search" link under the "Post New Topic" button. Put VIN in the search box. After you read all of those put "title" in the search box. You'll find hours of reading on this subject.
Apprentice
Apprentice
engine was trashed before i got the vehicle. Only have one number on the firewall
Ex Hall Monitor
Ex Hall Monitor
You'll need to contact your governmental titling authority & see what requirements they have. They might let you use the serial number, they might not.
Apprentice
Apprentice
i want to use the serial number the truck was registered to. I guess i can contact the OR dmv and find out the serial number they have on file for the plate.
The FB on the body serial number tells you that it is a 1936 half ton pickup. F=1936, B=half ton pickup.
Apprentice
Apprentice
wow the dmv has no record of the serial number or the plate number. apparently they purge after 10 years and this truck hasnt has a plate since 72. nice!
Apprentice
Apprentice
ok i took another look the serial is
5FB059077
Quote
5FB059077
Stick that number in the VIN Buster
It tells you that it's a 1936 1/2 ton with a 112inch wheelbase built in Kansas City, MO.
