1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Hi everyone! I am still trying to figure out what year my truck is. The title says 1952 but the Chevy Restoration gal says it's a 1955. Mike from Vancouver BC thought it was quite a conglomeration of parts. It looks like an original but the deeper I go into research I seem to find all kinds of differences. I will send pics if someone is kind enough to guide me through attachment process. It's in the Gallery under Mitch and Cindy's 1952 Ol Yeller. Thanks Mike! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tangovino, Could you post the numbers in question, all the clues to it being a 52-53 seem to be there to me. Angled top on the box, vent windows, push button door handles, split windshield, post the numbers and someone will decifer them, hope that helps. | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Thanks 3B! The data plate on the door reads: H53K035381 The VIN reads: 20KPJ6118 I know we have a 235 engine but the front fenders have yellow lights under the headlights in addition to the clear lights in the grill. Someone has said they looked like GMC fenders. I mailed Mike from BC interior shots to further help in this archeological exercise. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Using the two of the Stovebolt VIN decoders, the VIN translates to a 10/52 build date, made in sunny Los Angeles (Van Nuys.)
You might have an assortment of other year parts on it, but typically the VIN trumps all. Since you're titled as a '52, and the VIN shows a '52, I would call it a '52 regardless of the pedigree of the rest of the truck.
Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if GM told you either of those numbers are for a 55, they're blowin smoke .... it's a 52 by one number, a 53 by the other, a 55 year old truck with who knows how many previous owners making who knows what changes to keep it on the road, and changing things like the "yellow lights" to keep up with changing DMV regs .... the fact that you have a different vin number on the title than the one on the door plate is all that would concern me - means either someone has replaced the cab, or someone has found a title of a close year for a lost one, and also means if the man checks the title against the plate you might be in trouble!! Bill | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I didn't see where he said the title was different than the door plate. The title would most likely not show the body serial number unless it was retitled to show that instead of the engine serial number, as was done in most states. In California, at that time, the title only showed the year first sold, not the model year. The truck could have been first sold in 1952 with that build date, and would have been registered as a 1952. It would not be worth the trouble to have it retitled as a 1953 if that is the case. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | tangovino wrote: The data plate on the door reads: H53K035381 The VIN reads: 20KPJ6118 No where on a 52 or 53 Chevy is a number that's labeled VIN. The body serial number is the only correct VIN. I know, I know most states used the engine # as the VIN until the late 50's. But neither number is a valid engine number. The H53 is a 53 1/2 ton serial/vin and the 20KP is a 52 1/2 ton serial/vin. I think red58 has hit on something. Hey tangovino - does the title have 20KP... as the VIN? Either way the door tag correctly ID's the truck as a 53. Of course a lot can/does happen in 54-55 years.
Professional Novice
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd expect that what he means by "The VIN reads: 20KPJ6118" is the number that's on the title, as opposed to the number he says is on the door ... it is the case vehicles were titled by year of first sale, but he isn't saying the title calls it a year, just cites an "ID number" [VIN, which is what the line on the title would be headed], and the number on the door plate would still be the number put on the title, which doesn't seem to be the case I'm bettin changed cab or phoney title, trouble anyway .... unless you paint over the door plate Bill | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Sorry, I missed where he gave the VIN. I said I didn't see, but it was because I didn't look well enough. | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | So, what is the prognosis?
| | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Well looking at the photos above the hood emblem is the 3100 (53). Many of the specs point to 1952. At this point the wife and I are just happy we have a nice truck and it is running and it gives me a chance to relive an era my father existed in. 1952/53 can be sorta catchy. Keep 'em guessing. All I know is that it is a great piece of history and we are having a blast fixin' her up. Thanks everyone for your efforts. Pictures are on the way. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | After extensive research and deep thought, I can confidently say your truck is a 1989 Izuzu.  | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | At first I thought it was a 1947 Mobely Tri-Dog but alas no; I'm am satisfied with our '52/'53 old yellow Chevy 1/2 ton pickup. | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | what year is it?...last time i checked on the calendar,it said 2007...lol..Just kidding...  | | |
