0 members (),
49
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | I cant find this question addressed anywhere on the site. I occasionaly use my bolt for work around the house and yard. I need some ramps for a piece of rental equipment(lawn areator) for a project upcoming.What do you guys use? How do you use them? Do you lower the tailgate and hang it on the chains then lay some ramps on that? Will the chains hold the weight? Do any of you use the ones that you make from lumber? Do you just set them on the tailgate? I guess since our bolts use the chains I wonder how safe this is. I appreciate any ideas. My truck is a daily driver so Im not concerned about some scratches etc.I want to keep this on the cheap and I dont want to buy expensive ramps.
Thanks in advance. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kevs57,
The low budget but effective ramp is merely a fir 2X12 the length of the bed with a small piece of flatbar screwed to one end that catches in the space between lowered tailgate and bed.
Depending on what was being loaded, a pair of these might be needed. I think trying to load a heavy item across the chained up tailgate would only result in a bent gate.
Stuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i'd buy a slightly curved model i have several bikes and the need for a curved model is best. http://www.motorcycleramps.com/motorcycle-ramp.htm
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Get a sheet of 1 1/8" 'sturdi-floor" plywood. You can cut one wide one or two narrow ramps as you need. Use the piece of flatbar as Automarc described. Marty | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A ditch by a hill is the cheapest "ramp"
Drop the rear wheels in a ditch, and or back up to a bank / hill, no ramp needed.
If you don't have the perfect hill, then some planks from the bed, over the tailgate, to the hill may work.
Grigg | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can buy ramp ends like these. and put them on a pair of 2x12s like I did over 20 years ago. They are a bit heavier than the folding aluminum things you can buy now but they don't cost a fortune either.
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | Thank you gentlemen. A great help as usual. I will make a decision from your suggestions. I just got new painted bumpers and I was wondering how to do this without laying the tailgate on my new rear bumper! :blat: | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The tailgate shouldn't contact the bumper anyway. If it is, there be a problem somewhere.
| | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | You might be able to take a piece of rubber pipe insulation and cut it down the middle so you can slip it on the edge of your tailgate where the bumper will make contact to prevent damage when you take the chains off and lay the tailgate on the bumper. | | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | i have a set of 2x12's, I have to take off the tail gate tho, as it will hit the bumper if i take off the restraints.
