1 members (baldeagle),
94
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | Where is the best place to buy the brake line holders that hold the lines to the frame and the clips that hold the rubber hoses in place where the steel lines join them?? Is there a catalog of these things I can get my hands on?? Working on a 63 GMC k10 4x4. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You should be able to get them from the flaps. Jim Carter seems to have alot those small items like that, too.
Bill Burmeister | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | FLAPS=Friendly Auto Parts Store (in case you didn't know) | | | | | Joined: Dec 2004 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 58 | Performance online sells brake components. I picked up rear brakes for a '70 impala rear end. They also offer cross drilling the drums, which helps in cooling. Godman Hi-Performance and Pure Choice sell hoses, fittings, and clamps.
1954 custom 1-ton (1 of a kind) | | |
