8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall),
122
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | Anyone know how to remove the front and rear windshield on a 66 chev truck? Doing body work and want to make sure there isn't any cancer behind the gaskets. | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Well, I'll tell you what I did. first thing is to take your time. you don't want to crack it. I used a utility knife and just started to work outside where the glass is on the rubber. I kept peeling it away and slowly exposed the glass. Then I got the boss to keep her hands outside so the windshield wouldn't fall and gently pushed from the inside. Worked OK. I did the same with the rear window too as both were good glass. Needed new rubber anyway. Cab has been sandblasted now awaiting paint.
sovagary
GS
| | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Oh, one more thing. Do not let the utility knife touch the glass. It will break. Cut the rubber outside this area. no screwdrivers either.
sovagary
GS
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I usually cut on the inside, using a sharp blade, less risk to the glass. Just cut off the lip inside the truck, the glass will push out, have someone catch it as sovagary said. | | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | | | | | | Joined: Jan 2007 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 116 | how bout puting it back in rite im debatin bout takin my 64 glass out
LEWIS
