7 members (wilbur53, GMCJammer51, J Lucas, 3B, walter74, dt235sd, JW51), 108 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#237721 07/23/2007 4:15 PM
Junior Member
Junior Member
My 66 began to run quite rough all of a sudden. I had just put in 10 gallons on high "super unleaded" fuel. Is this not a recomended fuel for older trucks?
James T
www.fixmyprinter.com
But honey...its for us!
#237722 07/23/2007 6:47 PM
You don't need to run anything but cheap regular unleaded in a '66, but super shouldn't have made it run rough either, unless the fuel filter plugged up somehow.
Paint & Body Shop moderator
#237723 07/23/2007 10:05 PM
Like 4onthefloor says, you're just wasting your hard earned money by putting anything but 87 octane in your tank. All the higher octane fuel does is resist detonation for awhile, so it MAY be affecting your timing a small amount.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
