8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 3 Apprentice | | Apprentice Joined: Apr 2007 Posts: 3 | I have decided to do an S-10 chassis swap for my 50 chevy. I just got the frame, 4.3 liter v6, 5 spd tranny, and the guy let me switch out the rear end for a blazer rear end. All for $300.
I got it from a local wrecking yard and he has several more long bed s-10's if anyone wants them.
I need some WD-40 and a breaker bar!
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Sounds like you got a heck of a deal for $300. Good luck with your swap. | | | | | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | What made you decide on the frame swap? Also, are you doing it on your own or are you buying the kit from AD Engineering? Just wondering because I am getting close to deciding on what way to go with mine. | | | | | Joined: Jul 2005 Posts: 1 Junior Member | | Junior Member Joined: Jul 2005 Posts: 1 | I just rolled the S-10 Extended cab frame for my '50 GMC into the garage this afternoon. Same setup as youes but stock rearend. I have a Winters Quickchange that I will be using.
We shouold keep in touch and share our progress.
Glenn | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | One day i'd like to do that with a '47 thru '50 Chevy.. sit it on an s10 frame.
I'd hold out for a 4x4 frame, tho.. just so I could drive the truck year round.
That 4.3L engine is a good motor. Next best thing to a 350, IMO. I've had several, and they never gave me a bit of trouble.
