| | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 1 Junior Member | | Junior Member Joined: Jul 2007 Posts: 1 | Are all cabs the same or were there "A/C specific" cabs built for the trucks shipped with factory air? I have a 70 GMC that was not originaly equipped with A/C. I would like to put A/C in it and will need to figure out what my best options are. Any experience out there that anyone can share? | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | The AC cab is different. A vacuum operated fresh air vent is under the cowl, in the tray below the windshield. There are some other differences in the tin under there as well as the huge holes in the firewall are different. Vintage Air, Old Air and the others sell systems tailor made for the 67-72 chevy truck with AC cab or heater only cab.
'67 GMC 3/4 292 4spd
| | | | | Joined: Apr 2007 Posts: 3 Apprentice | | Apprentice Joined: Apr 2007 Posts: 3 | The best way to see tell if a cab has factory a/c is there will be a center vent above the stereo and an air vent on each lower outside corner of the dash. If you want the factory look you should find that cab or at least dash. They also make some aftermarket kits for these trucks that mount under the dash. These kits in my opinion dont look all that great.
On my last project (70 Chev 4x4 shortbed) My cab was rotton so I found an A/C cab rust free for $100 and had it all switched out in a day.
I need some WD-40 and a breaker bar!
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive seen it done where you can cut the hole out to match & put in the factory air. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I saw this truck on the 4th at a car show but was not able to locate the owner. Well detailed truck. I'm guessing Vintage air, but not sure. The center vent and AC control look very near the original. Vintage sells the side vents that also look like the original ball vents, but as you can see this guy chose a different style. The other advantage of using an after market setup is that the AC, heater and defroster are all under the dash. No steamer trunk sized suitcase that you have to reach over to touch the engine. picture 1 picture 2 picture 3
