3 members (Bill Hanlon, ShopRag, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23748 04/03/2002 5:57 AM | Joined: Apr 2002 Posts: 2 Junior Member | | Junior Member Joined: Apr 2002 Posts: 2 | I have a 55 1st series 1/2 ton, and I just aquired a boat, When I brought it home and attempted to back it up my GRAVEL driveway, I met with wheel spin on the right side. Does anyone know of a posi or locker for my truck? I talked to a friend who does rear end work, and he said I might try putting in extra thrust washers on the side and pinion gears if possible. Any help out there???
Thanks, partst | | |
#23749 04/04/2002 6:00 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Well, in high school, the guys with hot rod trucks just put a few bags of concrete in the bed to get the wheel planted. That would be the low $ solution. | | |
#23750 04/04/2002 6:06 AM | Joined: Jan 2002 Posts: 7 Member | | Member Joined: Jan 2002 Posts: 7 | No one makes a posi or locker that I know of, I had to go with a f#*# 9"in my 54. Drifter | | |
#23751 04/04/2002 2:37 PM | Joined: Apr 2002 Posts: 2 Junior Member | | Junior Member Joined: Apr 2002 Posts: 2 | Thanx for the input. A buddy called last night and said he has a complete 3rd member out of a '73 1/2 ton that is posi, although it has a tooth missing on the ring gear. I'm going to do some measuring this weekend and see what it looks kike. It will be hard to do this kind of change since the ONLY thing that is not stock on my '55 is the 12 volt system! | | |
#23752 04/04/2002 10:43 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you can find a dana 44 or 60 axle that fits there are tons of lockers available for them. Another really effective low buck solution is to rework the parking brake scheme and add another lever so you can set each side individually. This lets you tighten up the brake on the side that is spinning and with a little practice gives you all the traction control that you will need. You could use old willys parking brake handles (They are the pull out from the dash type and twist to release) or toyota/nissan truck levers. If you need to fabricate emergency brake cables then find a speedometer shop. A local one here made me some really nice metal/plastic sheathed huck type parking brake cables for $40 each just copying the old ones. They even had heavy duty control handles that you could use in this application.
Lockers can give iffy wet road handling characteristics and are unnecessary in most cases.
#23753 04/04/2002 10:46 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Oh yeah, since it is a boat trailer, try shifting the boat forward on the trailer by 6 inches or so to increase the tongue weight on the trailer hitch. That will make it ride better too.
