6 members (Nick in Manitou, Wayne67vert, 1955 1 Series, Oswald, Woodcmiami, MRMEROTH11), 147 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
8
Junior Member
Junior Member
8 Offline
With a new rodsteration, there are a few bugs to be worked out, and i'm swatting at a difficult one to kill.
While in the garage, the hood latch holds tight, get her on the road, hit a bump, the main latch gives way, letting the secondary latch keep the hood from making visibility an issue.
Any key points or tips on adjustment, everything looks good as far as the operating levers and springs go... i usually run into hoods that are hard to open... not this one
by the way... she's got 42 miles on her now!
I would think the threaded stud in the middle might need to be lowered by rotating counterclockwise a couple of turns
Hello, Welcome to America
press '1' for English
Puess '2' to disconnect until you learn to speak English
That would be my guess as well. The stud in the hood that kinda floats, and is tensioned by a spring. Well, okay, mine floats. Don't know if it's actually supposed to, but my hood works fine. No visibility problems to date, except when it rains and I'm going up a hill. But that's another issue.
1951 3800
-hotshoe
